Unit 8 list IO Check
Table list U8 (Group4: DCS)
[P01]
GENERATOR/MOTOR
DIFFERENTIAL
[P02]
GENERATOR/MOTOR
NAGATIVE SEQUENCE
[P03]
GENERATOR/MOTOR
VOLTAGE UNBALANE
[P04]
GENERATOR/MOTOR
OVER/UNDER
FEQUENCY
[P05]
GENERATOR/MOTOR
STATOR GROUND
FAULT
[P06]
GENERATOR/MOTOR
BUS GROUND
[P07]
EXCITATION FAULT
[P08]
GENERATOR/MOTOR
DISTANCE FAULT
[P09]
GENERATOR/MOTOR
PHASE SEQUENCE
[P10]
GENERATOR/MOTOR
OUT OF STEP
[P11]
GENERATOR/MOTOR
ROTOR GROUND FAULT
[P12]
EXCITATION TROUBLE
[P13]
EXCITATION
TRANSFORMER FAULT
[P14]
KG5A TRANSFORMER
TROUBLE
[P15]
KG5A
TRANSFORMER
FAULT
[P16]
KG5A
TRANSFORMER
OLTC TROUBLE
[P17]
MOTOR STARTING
FAULT
[P18]
UNIT 1/2 STARTING
TROUBLE
[P19]
MOTOR UNDER POWER
[P20]
MOTOR UNDER VOLTAGE
[P21]
DYNAMIC BRAKE
OVERCURRENT
[P22]
GENERATOR/MOTOR
ROTOR WIDING TEMP
HIGH
[P23]
GENERATOR/MOTOR
STATOR WIDING
TEMP HIGH
[P24]
BB 1382
STATING CIRCUIT
BREAKER FAIL
TO OPEN
[P25]
86-1 LOCKOUT
RELAY OPERATED
[P26]
86-2 LOCKOUT
RELAY OPERATED
[P27]
86-3 LOCKOUT
RELAY OPERATED
[P28]
86-TR LOCKOUT
RELAY OPERATED
[P29]
EMERGENCY
SHUTDOWN
[P30]
EMERGENCY STOP
[P31]
INTAKE GATE TROUBLE
[P32]
PUMP/TURBINE
BEARING
TEMPERATURE HIGH
[P33]
GENERATOR/MOTOR
BEARING TEMPERATURE
HIGH
[P34]
GENERATOR/MOTOR
BEARING OIL LEVEL
LOW
[P35]
GENERATOR/MOTOR
BEARING OIL TEMP
HIGH
[P36]
UNIT VIBRATION HIGH
[P37]
GOVERNOR
PRESSURE TANK
TROUBLE
[P38]
GOVERNOR
SUMP TANK
TROUBLE
[P39]
ELECTRONIC
GOVERNOR FAULT
[P40]
CO2 DISCHRAGE
[P41]
LABYRINTH SEAL COOLING
WATER FLOW LOW
[P42]
BB 1392A GEN/MOTOR
CIRCUIT BREAKER FAILURE
[P43]
BB 1382C STARTING
CIRCUIT BREAKER TROUBLE
[P44]
PUMP/TURBINE
BEARING OIL LEVEL
LOW
[P45]
WIVKET GATE FAULT
[P46]
UNIT OVERSPEED
[P47]
INLET VALE
PRESSURE TANK
TROUBLE
[P48]
NLET VALVE
SUMP TANK TROUBLE
[P49]
KG5A WATER SPRAY
FIRE EXTINGUISHING
[P50]
GOVERNOR
MAN OIL VALVE
TROUBLE
[P51]
INLET VALVE
MAIN OIL VALVE
TROUBLE
[P52]
DRAINAGE PIT
WATER LEVEL HIGH
[P53]
GENERATOR/MOTOR
OVERVOLTAGE
[P54]
GENERATOR/MOTOR
OVERCURRENT
[P55]
MOTOR UNDER
FREQUENCY
[P56]
STATION SEERVICE
TR PRESSURE RELIEVE
TRIPPED
[P57]
STATION SERVICE
TR WIND TEMP HIGH
TRIPPED
[P58]
STATION SERVICE
TR OIL,TEMP HIGH
TRIPPED
[P59]
STATION SERVICE
TR BUCHHOLTZ RELAY
TRIPPED
[P60]
STATION SERVICE
TR OLTC PROTECT RELAY
TRIPPED
[P61]
EXCITATION LIMITER
IN OPERATION
[P62]
BB 1381A/B
PHASE REVERSAL
SWITCH POLE TROUBLE
[P63]
BB 1381A,GEN/MOTOR
MAIN DISC
SWITCH POLE,TROUBLE
[P64]
BB 1391C STATION
SERVICE,DISC SWITCH
PLOE TROUBLE
[P65]
GENERATOR/MOTOR
BEARING TEMP
HIGH
[P66]
GENERATOR/MOTOR
BEARING OIL
LEVEL HIGH/LOW
[P67]
GENERATOR/MOTOR
BEARING OIL
TEMP HIGH
[P68]
GENERATOR/MOTOR
BEARING OIL
FLOW LOW
[P69]
GENERATOR/MOTOR
COOLING WATER
FLOW LOW
[P70]
GENERATOR/MOTOR
WDG/CORE
TEMP HIGH
[P71]
GENERATOR/MOTOR
AIR COOLING
TEMP HIGH
[P72]
BB 1382A GEN/MOTOR
CIRCUIT BREAKER
TROUBLE
